주요 콘텐츠로 건너뛰기
ProntoTec Axius Motherboard Replacement
필요한 것
  1. ProntoTec Axius Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table.
  2. ProntoTec Axius Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Motherboard Replacement: 4 단계, 이미지 2개 중 1개 ProntoTec Axius Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove only the yellow tape that touches the motherboard
    • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
  5. ProntoTec Axius Motherboard Replacement: 5 단계, 이미지 3개 중 1개 ProntoTec Axius Motherboard Replacement: 5 단계, 이미지 3개 중 2개 ProntoTec Axius Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
    • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
  6. ProntoTec Axius Motherboard Replacement: 6 단계, 이미지 2개 중 1개 ProntoTec Axius Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    • Use pliers to pull the wire from the board
  7. ProntoTec Axius Motherboard Replacement: 7 단계, 이미지 2개 중 1개 ProntoTec Axius Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
  8. ProntoTec Axius Motherboard Replacement: 8 단계, 이미지 3개 중 1개 ProntoTec Axius Motherboard Replacement: 8 단계, 이미지 3개 중 2개 ProntoTec Axius Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
    • Gently pull and remove the ribbon cables from the motherboard
  9. ProntoTec Axius Motherboard Replacement: 9 단계, 이미지 2개 중 1개 ProntoTec Axius Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Estelle Hatem
회원 가입일: 10/20/16
156 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 389
