주요 콘텐츠로 건너뛰기
Propel Gyro-X On-Board Battery Pack Replacement
필요한 것
  1. Propel Gyro-X On-Board Battery Pack Replacement, Bottom Propellor Blades: 1 단계, 이미지 1/1
    • Remove the two 5.0 mm Phillips #00 screws from the rotors.
    • The blades will fall off when the screws have been removed.
  2. Propel Gyro-X On-Board Battery Pack Replacement, Outer Shell: 2 단계, 이미지 1/1
    • Locate the nubs on either side of the helicopter.
  3. Propel Gyro-X On-Board Battery Pack Replacement: 3 단계, 이미지 1/1
    • Pull the body shell off of the nubs on both sides.
  4. Propel Gyro-X On-Board Battery Pack Replacement: 4 단계, 이미지 1/2 Propel Gyro-X On-Board Battery Pack Replacement: 4 단계, 이미지 2/2
    • Push the front of the nose back towards the tail of the helicopter.
    • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
  5. Propel Gyro-X On-Board Battery Pack Replacement, On-Board Battery Pack: 5 단계, 이미지 1/1
    • Do not cut battery wires simultaneously because this will cause a short circuit. Due to the unrestricted flow of electricity, a short circuit could cause bodily harm.
    • Pull the battery off of the holder.
    • Cut each of the wires to the battery one at a time using a pair of wire cutters.
    • To replace the battery, you will need to strip both of the wires from the circuit, and both of the wires from the battery. You will then need to twist and solder both pairs of wires(red to red, black to black). You can find directions on soldering here.
    • Once the wires are cut, strip and solder the wires connected to the Gyro-X to the wires of the new batter pack.
    • To learn how to solder follow the steps below How To Solder and Desolder Connections
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jack Jenner
회원 가입일: 04/08/15
293 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-2, Forte Spring 2015 Cal Poly, Team 17-2, Forte Spring 2015 회원
CPSU-FORTE-S15S17G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 15
전체 시간: 3,069
