주요 콘텐츠로 건너뛰기
Protocol Neo-Drone AP Motor Replacement
필요한 것
  1. Protocol Neo-Drone AP Motor Replacement, Motor: 1 단계, 이미지 1/2 Protocol Neo-Drone AP Motor Replacement, Motor: 1 단계, 이미지 2/2
    • Remove the four blades by pulling them off of the motors.
  2. Protocol Neo-Drone AP Motor Replacement: 2 단계, 이미지 1/1
    • Remove the blade guards by pushing the guards downward towards the padded feet.
  3. Protocol Neo-Drone AP Motor Replacement: 3 단계, 이미지 1/1
    • Remove the four 4.5mm Phillips #0 screws from the back panel.
  4. Protocol Neo-Drone AP Motor Replacement: 4 단계, 이미지 1/2 Protocol Neo-Drone AP Motor Replacement: 4 단계, 이미지 2/2
    • Use the flat end of a spudger to pry apart the the two pieces.
    • Lift the back panel up to separate it from the front panel.
  5. Protocol Neo-Drone AP Motor Replacement: 5 단계, 이미지 1/1
    • Pull the four motors out of the case.
    • The motors are still soldered to the motherboard.
  6. Protocol Neo-Drone AP Motor Replacement: 6 단계, 이미지 1/1
    • Here is a link to the iFixit Soldering Guide
    • Use a soldering iron to desolder the motors from the motherboard.
결론
Andrew
회원 가입일: 07/05/18
291 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G3, Harley Summer 2018 IUPUI, Team S2-G3, Harley Summer 2018 회원
IUPUI-HARLEY-SU18S2G3
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 405
