주요 콘텐츠로 건너뛰기
Protocol TerraCopter EVO Left & Right Joystick Replacement
필요한 것
  1. Protocol TerraCopter EVO Left & Right Joystick Replacement, Controller's battery: 1 단계, 이미지 2개 중 1개 Protocol TerraCopter EVO Left & Right Joystick Replacement, Controller's battery: 1 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
    • Remove the battery cover from the controller.
  2. Protocol TerraCopter EVO Left & Right Joystick Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all of four of the AA batteries from the controller.
  3. 주의: 3-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Protocol TerraCopter EVO Left & Right Joystick Replacement, Protocol TerraCopter EVO Controller Opening: 3 단계, 이미지 1개 중 1개
    • Note: the four Phillips screws on the rear panel are a millimeter longer than the two screws near the antenna and the two screws on the handle.
    • Orientate the controller to where the battery compartment is facing upwards.
    • Remove the four 5mm and four 4mm Phillips #1 screws from the case.
  4. Protocol TerraCopter EVO Left & Right Joystick Replacement: 4 단계, 이미지 1개 중 1개
    • Since the battery wires are still attached, carefully move the rear panel down to expose the motherboard.
  5. Protocol TerraCopter EVO Left & Right Joystick Replacement, Left & Right Joystick: 5 단계, 이미지 1개 중 1개
    • Remove the eight 5mm Phillips #1 screws from the motherboard.
  6. Protocol TerraCopter EVO Left & Right Joystick Replacement: 6 단계, 이미지 2개 중 1개 Protocol TerraCopter EVO Left & Right Joystick Replacement: 6 단계, 이미지 2개 중 2개
    • After removing the screws, orientate the motherboard to where the side with the black joysticks face upwards.
    • Pull the black plastic joysticks from the motherboard, out of their their assembly.
  7. Protocol TerraCopter EVO Left & Right Joystick Replacement: 7 단계, 이미지 1개 중 1개
    • Once the joysticks are removed, orientate the motherboard to where the green side is facing upwards.
    • On the green side of the motherboard, locate the two sets of ten pin arrays that hold the joystick assembly to the motherboard.
  8. Protocol TerraCopter EVO Left & Right Joystick Replacement: 8 단계, 이미지 1개 중 1개
    • Melt the existing solder points on the pin arrays with a soldering iron and lift the joystick assemblies from their location on the motherboard.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 263
