주요 콘텐츠로 건너뛰기
Protocol Videodrone AP Propeller Motors Replacement
필요한 것
  1. Protocol Videodrone AP Propeller Motors Replacement, Propeller Motors: 1 단계, 이미지 1/1
    • Power off the drone before proceeding with the rest of the guide.
  2. Protocol Videodrone AP Propeller Motors Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove four propeller screws.
    • If you don't own the screwdriver included with the drone kit, use a Phillips #0 screwdriver.
  3. Protocol Videodrone AP Propeller Motors Replacement: 3 단계, 이미지 1/2 Protocol Videodrone AP Propeller Motors Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove eight propeller guard screws.
  4. Protocol Videodrone AP Propeller Motors Replacement: 4 단계, 이미지 1/2 Protocol Videodrone AP Propeller Motors Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove eight housing screws from the bottom of the drone.
  5. Protocol Videodrone AP Propeller Motors Replacement: 5 단계, 이미지 1/1
    • Open up housing to reveal main circuit board.
  6. Protocol Videodrone AP Propeller Motors Replacement: 6 단계, 이미지 1/2 Protocol Videodrone AP Propeller Motors Replacement: 6 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove three motor housing screws. There are three screws per motor.
    • The plastic housing is glued directly to motor.
  7. Protocol Videodrone AP Propeller Motors Replacement: 7 단계, 이미지 1/3 Protocol Videodrone AP Propeller Motors Replacement: 7 단계, 이미지 2/3 Protocol Videodrone AP Propeller Motors Replacement: 7 단계, 이미지 3/3
    • Desolder the wires connecting the propeller motor to the motherboard (2 per motor) and remove the motor from the device.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Karan Paranganat
회원 가입일: 11/07/19
352 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G2, Harley Fall 2019 IUPUI, Team S2-G2, Harley Fall 2019 회원
IUPUI-HARLEY-F19S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 275
