주요 콘텐츠로 건너뛰기
Protocol Videodrone AP Propeller Motors Replacement
필요한 것
  1. Protocol Videodrone AP Propeller Motors Replacement, Propeller Motors: 1 단계, 이미지 1개 중 1개
    • Power off the drone before proceeding with the rest of the guide.
  2. Protocol Videodrone AP Propeller Motors Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove four propeller screws.
    • If you don't own the screwdriver included with the drone kit, use a Phillips #0 screwdriver.
  3. Protocol Videodrone AP Propeller Motors Replacement: 3 단계, 이미지 2개 중 1개 Protocol Videodrone AP Propeller Motors Replacement: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove eight propeller guard screws.
  4. Protocol Videodrone AP Propeller Motors Replacement: 4 단계, 이미지 2개 중 1개 Protocol Videodrone AP Propeller Motors Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove eight housing screws from the bottom of the drone.
  5. Protocol Videodrone AP Propeller Motors Replacement: 5 단계, 이미지 1개 중 1개
    • Open up housing to reveal main circuit board.
  6. Protocol Videodrone AP Propeller Motors Replacement: 6 단계, 이미지 2개 중 1개 Protocol Videodrone AP Propeller Motors Replacement: 6 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove three motor housing screws. There are three screws per motor.
    • The plastic housing is glued directly to motor.
  7. Protocol Videodrone AP Propeller Motors Replacement: 7 단계, 이미지 3개 중 1개 Protocol Videodrone AP Propeller Motors Replacement: 7 단계, 이미지 3개 중 2개 Protocol Videodrone AP Propeller Motors Replacement: 7 단계, 이미지 3개 중 3개
    • Desolder the wires connecting the propeller motor to the motherboard (2 per motor) and remove the motor from the device.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Karan Paranganat
회원 가입일: 11/07/19
352 평판
안내서 2개를 작성함
IUPUI, Team S2-G2, Harley Fall 2019 IUPUI, Team S2-G2, Harley Fall 2019 회원
IUPUI-HARLEY-F19S2G2
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 370
