주요 콘텐츠로 건너뛰기
Purple SmartVP Light Replacement
필요한 것
  1. Purple SmartVP Light Replacement, Light: 1 단계, 이미지 1/3 Purple SmartVP Light Replacement, Light: 1 단계, 이미지 2/3 Purple SmartVP Light Replacement, Light: 1 단계, 이미지 3/3
    • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
  2. Purple SmartVP Light Replacement: 2 단계, 이미지 1/2 Purple SmartVP Light Replacement: 2 단계, 이미지 2/2
    • Remove the 1.2 cm hex T9 screws and gently open up the device.
  3. Purple SmartVP Light Replacement: 3 단계, 이미지 1/2 Purple SmartVP Light Replacement: 3 단계, 이미지 2/2
    • Flip the top bar over and using a #00 phillips head screwdriver, remove the five 7mm screws holding the bar together.
  4. Purple SmartVP Light Replacement: 4 단계, 이미지 1/2 Purple SmartVP Light Replacement: 4 단계, 이미지 2/2
    • Carefully pry off the plastic panel, revealing the motherboard.
  5. Purple SmartVP Light Replacement: 5 단계, 이미지 1/2 Purple SmartVP Light Replacement: 5 단계, 이미지 2/2
    • Remove the two 7mm screws holding the motherboard in place with a phillips head screwdriver size #00.
  6. Purple SmartVP Light Replacement: 6 단계, 이미지 1/2 Purple SmartVP Light Replacement: 6 단계, 이미지 2/2
    • To release the motherboard from its plastic housing, first pull the plastic light covers up and away from the device.
  7. Purple SmartVP Light Replacement: 7 단계, 이미지 1/2 Purple SmartVP Light Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Heat the solder on the underside of the affected light to remove and replace it using tweezers.
    • Check out this helpful guide for some soldering and desoldering tips.
결론
Brian Maulucci
회원 가입일: 09/10/18
579 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 129
