주요 콘텐츠로 건너뛰기
Pyle Astro PTBL7C LCD Replacement
필요한 것
  1. Pyle Astro PTBL7C LCD Replacement, LCD: 1 단계, 이미지 2개 중 1개 Pyle Astro PTBL7C LCD Replacement, LCD: 1 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C LCD Replacement: 2 단계, 이미지 2개 중 1개 Pyle Astro PTBL7C LCD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C LCD Replacement: 3 단계, 이미지 1개 중 1개
    • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
    • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
  4. Pyle Astro PTBL7C LCD Replacement: 4 단계, 이미지 1개 중 1개
    • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
    • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
  5. Pyle Astro PTBL7C LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
  6. Pyle Astro PTBL7C LCD Replacement: 6 단계, 이미지 1개 중 1개
  7. Pyle Astro PTBL7C LCD Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
    • Exercise extreme caution and be sure to not rupture the battery casing.
  8. Pyle Astro PTBL7C LCD Replacement: 8 단계, 이미지 1개 중 1개
결론
작성자
2다른 기여자 명과 함께
Andrew Redifer
회원 가입일: 03/27/18
265 평판
안내서 2개를 작성함
IUPUI, Team S3-G6, Harley Spring 2018 IUPUI, Team S3-G6, Harley Spring 2018 회원
IUPUI-HARLEY-S18S3G6
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 412
