소개
The Pyle Astro's power button is a simple push button switch that is soldered onto the main PCB. Use this guide to replace your tablet's power button.
필요한 것
Using the plastic opening tool, work your way along the edge of the tablet.
Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
Place the front display assembly facing front side down to expose the inside.
Flip the PCB board upside down to expose the solder joints for the power button.
Gently de-solder the four solder joints of the push button switch (power button).
Install the new push button switch and solder all the connections back into place.
