주요 콘텐츠로 건너뛰기
RCA RCT6272W23 Display Replacement
필요한 것
  1. RCA RCT6272W23 Display Replacement, Case: 1 단계, 이미지 1/2 RCA RCT6272W23 Display Replacement, Case: 1 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Display Replacement: 2 단계, 이미지 1/2 RCA RCT6272W23 Display Replacement: 2 단계, 이미지 2/2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Display Replacement, Motherboard: 3 단계, 이미지 1/3 RCA RCT6272W23 Display Replacement, Motherboard: 3 단계, 이미지 2/3 RCA RCT6272W23 Display Replacement, Motherboard: 3 단계, 이미지 3/3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Display Replacement: 4 단계, 이미지 1/1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Display Replacement: 5 단계, 이미지 1/2 RCA RCT6272W23 Display Replacement: 5 단계, 이미지 2/2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Display Replacement: 6 단계, 이미지 1/1
    • Pull up the motherboard from the rest of the body.
  7. RCA RCT6272W23 Display Replacement, Display: 7 단계, 이미지 1/1
    • Using a plastic opening tool, pry the battery off of the rest of the body.
    • The battery is attached to the display with double sided tape. It may be best to have a new strip of double sided tape to reattach the battery.
  8. RCA RCT6272W23 Display Replacement: 8 단계, 이미지 1/3 RCA RCT6272W23 Display Replacement: 8 단계, 이미지 2/3 RCA RCT6272W23 Display Replacement: 8 단계, 이미지 3/3
    • Using a spudger, separate the display surface from the front cover.
    • Be careful not to break the tabs that hold the display screen in place.
    • A second spudger may be necessary to help hold the position of the display screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ross Pennala
회원 가입일: 03/19/15
214 평판
안내서 1개 작성함
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 회원
MTU-LAUER-S15S1G5
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 27
전체 시간: 2,300
