주요 콘텐츠로 건너뛰기
RCA RCT6272W23 Motherboard Replacement
필요한 것
  1. RCA RCT6272W23 Motherboard Replacement, Case: 1 단계, 이미지 1/2 RCA RCT6272W23 Motherboard Replacement, Case: 1 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Motherboard Replacement: 2 단계, 이미지 1/2 RCA RCT6272W23 Motherboard Replacement: 2 단계, 이미지 2/2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 RCA RCT6272W23 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 RCA RCT6272W23 Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Motherboard Replacement: 5 단계, 이미지 1/2 RCA RCT6272W23 Motherboard Replacement: 5 단계, 이미지 2/2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull up the motherboard from the rest of the body.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Stephen Radachy
회원 가입일: 03/17/15
819 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 회원
MTU-LAUER-S15S1G5
2 회원들
안내서 12개 작성하였습니다
댓글 한 개
i need to know everything there is about the motherboard. an tablet. images, info etc
Paul Shreves - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 2,088
