주요 콘텐츠로 건너뛰기
RCA RCT6272W23 Speaker Replacement
필요한 것
  1. RCA RCT6272W23 Speaker Replacement, Case: 1 단계, 이미지 1/2 RCA RCT6272W23 Speaker Replacement, Case: 1 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Speaker Replacement: 2 단계, 이미지 1/2 RCA RCT6272W23 Speaker Replacement: 2 단계, 이미지 2/2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove the soldered wire connections to the speaker.
    • Soldering irons can cause burns and severely damage your device. If in doubt, pause and think about it.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Speaker Replacement: 4 단계, 이미지 1/1
    • Pry the speaker gently out of its plastic enclosure using a spudger.
결론
Stephen Radachy
회원 가입일: 03/17/15
819 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 회원
MTU-LAUER-S15S1G5
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 371
