이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
The new wires must be soldered back into place on the motherboard at the original location.
For tips on soldering techniques, see this Soldering Guide.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 7개
Links on ordering replacement batteries
Great step by step instructions not for novices!
i liked good job
where do i order the battery for RCT6378W2
RCT6378W2 where can i get a replacement battery
