주요 콘텐츠로 건너뛰기
RCA RCT6773W22 Motherboard Replacement
필요한 것
  1. RCA RCT6773W22 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 RCA RCT6773W22 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Motherboard Replacement: 2 단계, 이미지 1/3 RCA RCT6773W22 Motherboard Replacement: 2 단계, 이미지 2/3 RCA RCT6773W22 Motherboard Replacement: 2 단계, 이미지 3/3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Motherboard Replacement: 3 단계, 이미지 1/3 RCA RCT6773W22 Motherboard Replacement: 3 단계, 이미지 2/3 RCA RCT6773W22 Motherboard Replacement: 3 단계, 이미지 3/3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Motherboard Replacement, Speaker: 4 단계, 이미지 1/3 RCA RCT6773W22 Motherboard Replacement, Speaker: 4 단계, 이미지 2/3 RCA RCT6773W22 Motherboard Replacement, Speaker: 4 단계, 이미지 3/3
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
  5. RCA RCT6773W22 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 RCA RCT6773W22 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 RCA RCT6773W22 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Use the spudger to lift up the black tab on all three ZIF connectors.
    • Use tweezers to remove the ribbon cables from the zift connectors.
  6. RCA RCT6773W22 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use Phillips #000 screwdriver to remove the three 3mm screws on the motherboard.
  7. RCA RCT6773W22 Motherboard Replacement: 7 단계, 이미지 1/2 RCA RCT6773W22 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use a spudger or plastic opening tool to lift up the motherboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Kelsea Weber
회원 가입일: 11/12/15
19,873 평판
안내서 32개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 7
30일 전: 17
전체 시간: 2,973
