소개
This guide will illustrate how to remove the speaker.
필요한 것
Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
Place the plastic opening tool between the case and the screen.
Slide the tool clockwise around the case until all the clips are removed.
My tablet gets hot to were it smells melts and burns me
Yikes! It sounds like your battery might be overheating. Try opening up the tablet and check the condition of the battery. It will probably need to be replaced.
Desolder the wire connected from the speaker to the motherboard.
Pry the speaker from the casing with a plastic opening tool.
다른 한 분이 해당 안내서를 완성하였습니다.
