주요 콘텐츠로 건너뛰기
Razer BlackShark V2 Ear Cushion Replacement
필요한 것
  1. Razer BlackShark V2 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 1개 중 1개
    • Place the headset so that the left side is facing you.
    • The left side of the headset has the cable attachment and the volume control knob.
  2. Razer BlackShark V2 Ear Cushion Replacement: 2 단계, 이미지 1개 중 1개
    • Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
    • You should feel a hard plastic ridge.
    • Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
    • Slowly apply pressure to prevent damage.
  3. Razer BlackShark V2 Ear Cushion Replacement: 3 단계, 이미지 1개 중 1개
  4. Razer BlackShark V2 Ear Cushion Replacement: 4 단계, 이미지 2개 중 1개 Razer BlackShark V2 Ear Cushion Replacement: 4 단계, 이미지 2개 중 2개
    • Once the cushion is removed, make sure the hard plastic base with the clips is attached to it.
    • If you are replacing both ear cushions, repeat Steps 1-4 for the other side. Then, insert the new ear cushions by lining up the clips in their respective holes and applying even pressure until they audibly click.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
BlakeB
회원 가입일: 03/08/23
545 평판
안내서 3개를 작성함
댓글 2개
Thanks - this was very helpful. It was difficult to remove the retainer clip using my fingers - I found it much easier to use the back of a spoon (with a rounded edge) and getting more leverage that way.
Peter Gu - 답글
can someone pls tell me what's the size or mm of the foam?
Lorraine Corda - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 25
지난 30일: 115
전체 시간: 3,213
