주요 콘텐츠로 건너뛰기
Razer Blackwidow Chroma Key Switch Replacement
필요한 것
  1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: 1 단계, 이미지 1/2 Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: 1 단계, 이미지 2/2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: 2 단계, 이미지 1/2 Razer Blackwidow Chroma Key Switch Replacement, Front Panel: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: 3 단계, 이미지 1/2 Razer Blackwidow Chroma Key Switch Replacement, Back Panel: 3 단계, 이미지 2/2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 4 단계, 이미지 1/3 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 4 단계, 이미지 2/3 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 4 단계, 이미지 3/3
    • De-solder the anchor of each key that you desire to replace with a soldering iron.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the key switch once the de-soldering is complete.
결론
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
hello where to buy the switches for this keyboard?
ninja636 - 답글
I've seen Razer Green Switches (the ones for the Blackwidow) with RGB lighting available for sale on eBay.
I hope that helps!
Matt Von Grimm -
Hi Annika, I have razer black widow chroma overwatch edition, Is gateron optical switch compatible with it?
Jaydeep Parmar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 71
30일 전: 351
전체 시간: 20,854
