주요 콘텐츠로 건너뛰기
Razer Blade 15" (2020) Left Fan Replacement
필요한 것
  1. Razer Blade 15" (2020) Left Fan Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Left Fan Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Left Fan Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Left Fan Replacement, Label the antenna cables: 8 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Label the antenna cables: 8 단계, 이미지 2개 중 2개
    • In the next two steps, you'll disconnect the Wi-Fi antenna cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
  9. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
    • During reassembly, align the connector over its socket and gently press down with the flat end of your spudger or your fingernail until it clicks into place.
  10. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the screen press connector: 10 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the screen press connector: 10 단계, 이미지 2개 중 2개
    • Grab the pull tab on the screen connector.
    • Pull up to disconnect the connector from its socket.
    • During reassembly, align the connector over its socket and press down until it clicks into place.
  11. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: 11 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: 11 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: 11 단계, 이미지 3개 중 3개
    • Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
  12. Razer Blade 15" (2020) Left Fan Replacement, Move the charging cable: 12 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Move the charging cable: 12 단계, 이미지 2개 중 2개
    • Move the charging cable over the right edge of the laptop.
  13. Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: 13 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: 13 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: 13 단계, 이미지 3개 중 3개
    • Unclip the screen and antenna cables from the fan and move them over the right edge of the laptop.
  14. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the left fan: 14 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the left fan: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to grab the rubber sleeve around the left fan cable and pull the connector straight out of its socket.
  15. Razer Blade 15" (2020) Left Fan Replacement, Unfasten the left fan: 15 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 6.7 mm screws securing the left fan.
  16. Razer Blade 15" (2020) Left Fan Replacement, Remove the left fan: 16 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Left Fan Replacement, Remove the left fan: 16 단계, 이미지 2개 중 2개
    • Remove the left fan.
결론
작성자
1다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,932개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 24
전체 시간: 731
