주요 콘텐츠로 건너뛰기
Razer Blade 15" (2020) Right Fan Replacement
필요한 것
  1. Razer Blade 15" (2020) Right Fan Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Right Fan Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Right Fan Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Right Fan Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Right Fan Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Right Fan Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Right Fan Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Right Fan Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Right Fan Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Right Fan Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Right Fan Replacement, Disconnect the left-side screen cable: 8 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Disconnect the left-side screen cable: 8 단계, 이미지 2개 중 2개
    • Grab the pull tab on the neck of the left-side screen connector and pull it straight out of its socket.
  9. Razer Blade 15" (2020) Right Fan Replacement, Unclip the screen cable: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Unclip the screen cable: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Right Fan Replacement, Unclip the screen cable: 9 단계, 이미지 3개 중 3개
    • Pull the left-side screen cable out from the clips along the left edge of the fan.
  10. Razer Blade 15" (2020) Right Fan Replacement, Disconnect the right fan: 10 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Disconnect the right fan: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to grab the rubber sleeve around the right fan cable and pull the connector straight out of its socket.
  11. Razer Blade 15" (2020) Right Fan Replacement, Peel up the fan tape: 11 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Peel up the fan tape: 11 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Right Fan Replacement, Peel up the fan tape: 11 단계, 이미지 3개 중 3개
    • Use tweezers to peel the right side of the fan tape from the heatsink.
  12. Razer Blade 15" (2020) Right Fan Replacement, Unfasten the right fan: 12 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 6.7 mm screws securing the right fan.
  13. Razer Blade 15" (2020) Right Fan Replacement, Remove the right fan: 13 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Right Fan Replacement, Remove the right fan: 13 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Right Fan Replacement, Remove the right fan: 13 단계, 이미지 3개 중 3개
    • Lift the lower edge of the right fan and slide it away from the heatsink.
    • Remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,932개를 작성함
1가이드 댓글
The exact article I was looking for. Thanks for easy instructions that works!
Marty Robinson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 43
전체 시간: 887
