주요 콘텐츠로 건너뛰기
Razer Blade 15" (2020) SSD Replacement
필요한 것
  1. Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) SSD Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) SSD Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) SSD Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) SSD Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: 8 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: 8 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: 8 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the 3.1 mm screw securing the SSD.
    • The SSD will pop up slightly.
  9. Razer Blade 15" (2020) SSD Replacement, Remove the SSD: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) SSD Replacement, Remove the SSD: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) SSD Replacement, Remove the SSD: 9 단계, 이미지 3개 중 3개
    • Pull the SSD straight out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle before lowering it flat to the frame and securing it with its screw.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,932개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 915
