주요 콘텐츠로 건너뛰기
Razer Blade 15" (2020) Screen Replacement
필요한 것
  1. Razer Blade 15" (2020) Screen Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Screen Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Screen Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Screen Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Screen Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Screen Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Screen Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Screen Replacement, Label the antenna cables: 8 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Label the antenna cables: 8 단계, 이미지 2개 중 2개
    • In the next two steps, you'll disconnect the Wi-Fi antenna cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
  9. Razer Blade 15" (2020) Screen Replacement, Disconnect the antenna cables: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Disconnect the antenna cables: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Disconnect the antenna cables: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
    • During reassembly, align the connector over its socket and gently press down with the flat end of your spudger or your fingernail until it clicks into place.
  10. Razer Blade 15" (2020) Screen Replacement, Disconnect the screen press connector: 10 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Disconnect the screen press connector: 10 단계, 이미지 2개 중 2개
    • Grab the pull tab on the screen connector.
    • Pull up to disconnect the connector from its socket.
    • During reassembly, align the connector over its socket and press down until it clicks into place.
  11. Razer Blade 15" (2020) Screen Replacement, Disconnect the charging port: 11 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Disconnect the charging port: 11 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Disconnect the charging port: 11 단계, 이미지 3개 중 3개
    • Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
  12. Razer Blade 15" (2020) Screen Replacement, Move the charging cable: 12 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Move the charging cable: 12 단계, 이미지 2개 중 2개
    • Move the charging cable over the right edge of the laptop.
  13. Razer Blade 15" (2020) Screen Replacement, Unfasten the right hinge cover: 13 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 6.7 mm screws securing the right hinge cover.
  14. Razer Blade 15" (2020) Screen Replacement, Remove the right hinge cover: 14 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Remove the right hinge cover: 14 단계, 이미지 2개 중 2개
    • Remove the right hinge cover.
  15. Razer Blade 15" (2020) Screen Replacement, Pry up the charging port: 15 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Pry up the charging port: 15 단계, 이미지 2개 중 2개
    • Hold the charging port cables out of the way of the heatsink.
    • Use the flat end of your spudger to pry up the top screw mount of the charging port until it clears the hinge.
  16. Razer Blade 15" (2020) Screen Replacement, Remove the charging port: 16 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Remove the charging port: 16 단계, 이미지 2개 중 2개
    • Rotate the charging port counterclockwise and slide the lower screw mount out from underneath the motherboard.
    • Remove the charging port.
  17. Razer Blade 15" (2020) Screen Replacement, Disconnect the left-side screen cable: 17 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Disconnect the left-side screen cable: 17 단계, 이미지 2개 중 2개
    • Grab the pull tab on the neck of the left-side screen connector and pull it straight out of its socket.
  18. Razer Blade 15" (2020) Screen Replacement, Unclip the screen cable: 18 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Unclip the screen cable: 18 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Unclip the screen cable: 18 단계, 이미지 3개 중 3개
    • Pull the left-side screen cable out from the clips along the left edge of the fan.
  19. Razer Blade 15" (2020) Screen Replacement, Unfasten the left hinge cover: 19 단계, 이미지 1개 중 1개
    • Use your Phillips screwdriver to remove the two 6.7 mm screws securing the left hinge cover.
    • Depending on the condition of your screwdrivers, either a Phillips #1 or Phillips #0 will work.
  20. Razer Blade 15" (2020) Screen Replacement, Remove the left hinge cover: 20 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Remove the left hinge cover: 20 단계, 이미지 2개 중 2개
    • Remove the left hinge cover.
  21. Razer Blade 15" (2020) Screen Replacement, Unclip the right-side screen and antenna cables: 21 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Screen Replacement, Unclip the right-side screen and antenna cables: 21 단계, 이미지 2개 중 2개
    • Unclip the right-side screen and antenna cables from the fan and move them over the right side of the laptop.
  22. Razer Blade 15" (2020) Screen Replacement, Prop up your laptop: 22 단계, 이미지 1개 중 1개
  23. Razer Blade 15" (2020) Screen Replacement, Unfasten the hinges: 23 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Unfasten the hinges: 23 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Unfasten the hinges: 23 단계, 이미지 3개 중 3개
    • Hold the laptop steady with one hand.
    • Use your Phillips screwdriver to remove the five 4.7 mm screws securing the screen hinges.
  24. Razer Blade 15" (2020) Screen Replacement, Remove the screen: 24 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Screen Replacement, Remove the screen: 24 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Screen Replacement, Remove the screen: 24 단계, 이미지 3개 중 3개
    • Hold both halves of the laptop steady during this step, as they might fall unexpectedly.
    • Slide the screen hinges away from the frame to free them from their recesses.
    • Remove the screen.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,932개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 45
전체 시간: 1,635
