주요 콘텐츠로 건너뛰기
Razer Blade 15" (2020) Speakers Replacement
필요한 것
  1. Razer Blade 15" (2020) Speakers Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Speakers Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Speakers Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Speakers Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Speakers Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Speakers Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Speakers Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Speakers Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Speakers Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Speakers Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Speakers Replacement, Disconnect the right speaker: 8 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Disconnect the right speaker: 8 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Speakers Replacement, Disconnect the right speaker: 8 단계, 이미지 3개 중 3개
    • Use the point of your spudger to press on alternating sides of the right speaker (labeled R) connector to "walk" it out of its socket.
  9. Razer Blade 15" (2020) Speakers Replacement, Unfasten the right speaker: 9 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Unfasten the right speaker: 9 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 7.6 mm screws securing the right speaker.
  10. Razer Blade 15" (2020) Speakers Replacement, Remove the right speaker: 10 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Remove the right speaker: 10 단계, 이미지 2개 중 2개
    • Remove the right speaker
  11. Razer Blade 15" (2020) Speakers Replacement, Disconnect the left speaker: 11 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Disconnect the left speaker: 11 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Speakers Replacement, Disconnect the left speaker: 11 단계, 이미지 3개 중 3개
    • Use the point of your spudger to press on alternating sides of the left speaker (labeled L) connector to "walk" it out of its socket.
    • If the cable is tightly wedged under the Wi-Fi card, use your Phillips screwdriver to slightly loosen the screw securing it, freeing the speaker cable.
  12. Razer Blade 15" (2020) Speakers Replacement, Unfasten the left speaker: 12 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Unfasten the left speaker: 12 단계, 이미지 2개 중 2개
    • Use your Phillips screwdriver to remove the two 7.6 mm screws securing the left speaker.
  13. Razer Blade 15" (2020) Speakers Replacement, Remove the left speaker: 13 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Remove the left speaker: 13 단계, 이미지 2개 중 2개
    • Remove the left speaker.
  14. Razer Blade 15" (2020) Speakers Replacement, Reassembly information: 14 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Speakers Replacement, Reassembly information: 14 단계, 이미지 2개 중 2개
    • During reassembly, make sure the rubber grommets are in place at each screw cutout. You might need to transfer them to your new speakers.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
81,883 평판
안내서 455개를 작성함
Guide Team Guide Team 회원
Staff
9 회원들
안내서 11,421개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 430
