주요 콘텐츠로 건너뛰기
Razer Blade RZ09-0102 Battery Replacement
필요한 것
  1. Razer Blade RZ09-0102 Battery Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Razer Blade RZ09-0102 Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
  5. Razer Blade RZ09-0102 Battery Replacement: 5 단계, 이미지 2개 중 1개 Razer Blade RZ09-0102 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Battery Replacement: 6 단계, 이미지 2개 중 1개 Razer Blade RZ09-0102 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Battery Replacement: 7 단계, 이미지 2개 중 1개 Razer Blade RZ09-0102 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the battery from the laptop.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Nicole Schukow
회원 가입일: 10/03/18
462 평판
안내서 2개를 작성함
2가이드 댓글
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
Erfan Moradi - 답글
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
Giorgi Kikuashvili - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 41
전체 시간: 26,756
