주요 콘텐츠로 건너뛰기
Razer Kraken 7.1 Chroma Speaker Replacement
필요한 것
  1. Razer Kraken 7.1 Chroma Speaker Replacement, Ear Cushion: 1 단계, 이미지 1/1
    • Grab the ear cushion between your thumb and forefinger.
  2. Razer Kraken 7.1 Chroma Speaker Replacement: 2 단계, 이미지 1/1
    • Pull the ear cushion away from the speaker by sliding down to release the cushion from the plastic covering.
  3. Razer Kraken 7.1 Chroma Speaker Replacement: 3 단계, 이미지 1/1
    • Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed.
  4. Razer Kraken 7.1 Chroma Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Razer Kraken 7.1 Chroma Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Razer Kraken 7.1 Chroma Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
    • Insert the plastic spudger in between the speaker and the headset directly in line with one of the exposed screws of the headset casing, since that is where the four clamps that hold the speaker to the headset are located. These clamps are not visible until after speaker removal.
    • Make sure to insert the spudger in between the foam buffer-ring and the headset casing instead of in between the speaker and the foam buffer-ring.
    • Reassembly may be tricky, there is one clamp smaller than others, so you have to align it correctly.
  5. Razer Kraken 7.1 Chroma Speaker Replacement: 5 단계, 이미지 1/1
    • Cut both wires connecting the speaker to the headset by using a wire stripper or pair of scissors.
    • Cut as close as possible to the connections on the speaker circuit board.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Karissa Sealey
회원 가입일: 03/24/17
995 평판
안내서 4개 작성하였습니다
Baylor, Team S5-G3, Williams Spring 2017 Baylor, Team S5-G3, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G3
3 회원들
안내서 8개 작성하였습니다
댓글 2개
Hey nice guide, i would like to know which cable color goes where (step 5)
gianluca - 답글
Where i can but a replacement headset speaker for Razer Kraken pro neon
Rino Pasamonte - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 27
전체 시간: 8,740
