주요 콘텐츠로 건너뛰기
Razer Kraken Ultimate Microphone Replacement
필요한 것
  1. Razer Kraken Ultimate Microphone Replacement, Ear Pads: 1 단계, 이미지 1/3 Razer Kraken Ultimate Microphone Replacement, Ear Pads: 1 단계, 이미지 2/3 Razer Kraken Ultimate Microphone Replacement, Ear Pads: 1 단계, 이미지 3/3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Microphone Replacement: 2 단계, 이미지 1/2 Razer Kraken Ultimate Microphone Replacement: 2 단계, 이미지 2/2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Microphone Replacement: 3 단계, 이미지 1/2 Razer Kraken Ultimate Microphone Replacement: 3 단계, 이미지 2/2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Microphone Replacement, Speaker: 4 단계, 이미지 1/3 Razer Kraken Ultimate Microphone Replacement, Speaker: 4 단계, 이미지 2/3 Razer Kraken Ultimate Microphone Replacement, Speaker: 4 단계, 이미지 3/3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Microphone Replacement: 5 단계, 이미지 1/2 Razer Kraken Ultimate Microphone Replacement: 5 단계, 이미지 2/2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Microphone Replacement: 6 단계, 이미지 1/2 Razer Kraken Ultimate Microphone Replacement: 6 단계, 이미지 2/2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
  7. Razer Kraken Ultimate Microphone Replacement, Microphone: 7 단계, 이미지 1/3 Razer Kraken Ultimate Microphone Replacement, Microphone: 7 단계, 이미지 2/3 Razer Kraken Ultimate Microphone Replacement, Microphone: 7 단계, 이미지 3/3
    • Remove the two 10 mm Phillips #00 screws securing the microphone.
  8. Razer Kraken Ultimate Microphone Replacement: 8 단계, 이미지 1/1
    • Gently pry the bottom connection away from the casing with the iFixit opening tool.
  9. Razer Kraken Ultimate Microphone Replacement: 9 단계, 이미지 1/2 Razer Kraken Ultimate Microphone Replacement: 9 단계, 이미지 2/2
    • Pull the microphone down and out of the casing.
  10. Razer Kraken Ultimate Microphone Replacement: 10 단계, 이미지 1/1
    • Open up the casing the microphone retracks into.
    • Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
    • The casing the microphone if removed correctly in the previous step is easily opened by hand
결론
Tucker Murphy
회원 가입일: 10/26/22
115 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-4, Petersen Fall 2022 UMass Dartmouth, Team 1-4, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G4
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 26
전체 시간: 560
