주요 콘텐츠로 건너뛰기
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement
필요한 것
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement, Microphone Boom: 1 단계, 이미지 1/1
    • Remove the left ear cushion by rotating it counterclockwise as far as possible.
    • Pull the cushion upwards to remove it from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 2 단계, 이미지 1/3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 2 단계, 이미지 2/3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 2 단계, 이미지 3/3
    • Remove the six 6 mm screws around the speaker housing.
    • Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 3 단계, 이미지 1/1
    • Remove the three 6 mm screws on the inside of the ear cup.
  4. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 4 단계, 이미지 1/2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 4 단계, 이미지 2/2
    • There are two wires going into the boom. One powers the LED lights and the other goes to the microphone. Each wire has two smaller ones in them.
    • Cut both wires, strip the shielding, solder the new wires together, and wrap them in electrical tape or use heat shrink. Be sure to insulate the wires from each other.
    • The two sets of wires are different colors, so you can figure out which wire powers the LEDs and which goes to the microphone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Samokyszyn
회원 가입일: 02/24/14
359 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개 작성하였습니다
댓글 3개
Ok, so where does one get a replacement boom mic?
stolensoulz79 - 답글
My classmate saw a pair of headphones on a
website today. He thought it was nice looking and good price. He asked me my
opinion. What do you think? Here is the link:
kobe - 답글
opinion. What do you think? Here is the link: http://menghu.ebcoo.net/product/original...
kobe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 2,730
