주요 콘텐츠로 건너뛰기
Remington MB4040 Thermal Switch Replacement
필요한 것
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 2개 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 3개
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 2개
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 2개 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 3개
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 2개
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 2개
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 6 단계, 이미지 2개 중 1개 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 6 단계, 이미지 2개 중 2개
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: 7 단계, 이미지 1개 중 1개
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cameron Carnahan
회원 가입일: 01/20/15
1,112 평판
안내서 6개를 작성함
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G5
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 3,158
