주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Remington MB4040 Zoom Wheel Replacement
필요한 것
    1. Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 1개 Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 2개 Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 3개
      • Press the black button below the blade to remove the blade.
      댓글 쓰기
    2. Remington MB4040 Zoom Wheel Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 1개 Remington MB4040 Zoom Wheel Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 2개
      • Place the device so the back of the product is facing up.
      • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
      댓글 쓰기
    3. Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 1개 Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 2개 Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 3개
      • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
      • Remove the small clear plastic piece that covers the zoom wheel numbers.
      댓글 쓰기
    4. Remington MB4040 Zoom Wheel Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 1개 Remington MB4040 Zoom Wheel Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 2개
      • Remove the two 16.0 mm PH00 screws from the front cover.
      • Use the blue plastic opening tool to pry apart the two halves of the device.
      댓글 쓰기
    5. Remington MB4040 Zoom Wheel Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 1개 Remington MB4040 Zoom Wheel Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 2개
      • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
      • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
      댓글 쓰기
    1. Remington MB4040 Zoom Wheel Replacement, Remove screws attaching the zoom wheel: 6 단계, 이미지 2개 중 1개 Remington MB4040 Zoom Wheel Replacement, Remove screws attaching the zoom wheel: 6 단계, 이미지 2개 중 2개
      • Remove the two 11.0 mm PH00 screws that attach the zoom wheel to the plastic housing.
      댓글 쓰기
    2. Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: 7 단계, 이미지 3개 중 1개 Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: 7 단계, 이미지 3개 중 2개 Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: 7 단계, 이미지 3개 중 3개
      • Remove zoom wheel assembly from housing using fingers.
      • Gently remove zoom wheel assembly because the red and black wires are attached and can easily be broken.
      • This assembly also houses the motor.
      • Remove the small black piece of plastic surrounding the zoom wheel. This will be referred to as the slider.
      • When reassembling, make sure the pins on the slider are aligned inside the grooves of the wheel.
      댓글 쓰기
    3. Remington MB4040 Zoom Wheel Replacement, Wheel removal: 8 단계, 이미지 3개 중 1개 Remington MB4040 Zoom Wheel Replacement, Wheel removal: 8 단계, 이미지 3개 중 2개 Remington MB4040 Zoom Wheel Replacement, Wheel removal: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • A pin holds the wheel in place. Using a spudger (preferable metal) and a pair of pliers or tweezers remove the pin to unseat the wheel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cameron Carnahan
회원 가입일: 01/20/15
1,112 평판
안내서 6개를 작성함
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G5
3 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 43
전체 시간: 3,731
