주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Removing Solid-State Drive (SSD) shielding
필요한 것
  1. Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: 1 단계, 이미지 2개 중 1개 Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: 1 단계, 이미지 2개 중 2개
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
  2. Removing Solid-State Drive (SSD) shielding, Disconnect battery cable: 3 단계, 이미지 1개 중 1개
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
  3. Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: 4 단계, 이미지 2개 중 1개 Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: 4 단계, 이미지 2개 중 2개
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
  4. Removing Solid-State Drive (SSD) shielding, Remove the solid-state drive (SSD) shielding: 5 단계, 이미지 1개 중 1개
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
결론
작성자
1다른 기여자 명과 함께
johann beda
회원 가입일: 09/13/10
3,428 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 55
