주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Removing System board
필요한 것
추천 문서
  1. Removing System board, Remove screws from bottom of laptop.: 1 단계, 이미지 2개 중 1개 Removing System board, Remove screws from bottom of laptop.: 1 단계, 이미지 2개 중 2개
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
  2. Removing System board, Disconnect battery cable: 3 단계, 이미지 1개 중 1개
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
  3. Removing System board, Remove battery screws: 4 단계, 이미지 1개 중 1개
    • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    • Lift out the battery.
  4. Removing System board, Remove the system board mylar: 6 단계, 이미지 2개 중 1개 Removing System board, Remove the system board mylar: 6 단계, 이미지 2개 중 2개
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
  5. Removing System board, Remove the solid-state drive (SSD) shielding: 7 단계, 이미지 1개 중 1개
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
  6. Removing System board, Unscrew Solid-State Drives (SSD): 8 단계, 이미지 1개 중 1개
    • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
    • Remove each SSD by pulling it away from the slot.
    • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
  7. Removing System board, Remove the Wi-Fi card: 10 단계, 이미지 1개 중 1개
    • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
    • Remove 1 silver 2mm PH1 screw (M2 x L2).
    • Remove the Wi-Fi card by pulling it away from the slot.
  8. Removing System board, Disconnect tape and cables: 11 단계, 이미지 1개 중 1개
    • (1) Peel off the thermal DIMM plate tape from the system board.
    • (2-3) Lift flap and disconnect the I/O board cable from the system board.
    • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
    • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
    • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
  9. Removing System board, Disconnect the fan cables: 12 단계, 이미지 1개 중 1개
    • Disconnect the three fan cables from the system board by lifting away from board.
  10. Removing System board, Remove screws and fans: 13 단계, 이미지 1개 중 1개
    • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
    • Remove tape from fans - possibly using gentle heat
    • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
  11. Removing System board, Disconnect cables: 14 단계, 이미지 1개 중 1개
    • Disconnect 9 cables connected to the system board.
  12. Removing System board, Disconnect more cables: 15 단계, 이미지 1개 중 1개
    • Disconnect five more cables from the system board
    • Remove 3 black 4mm PH1 screws (M2 x L4) screws
    • Remove 2 black 6mm PH1 screws (M2 x L4) screws
    • Remove the flaps of tape holding the antenna wires to the board.
    • Remove the system board module carefully.
결론
첨부 문서
작성자
1다른 기여자 명과 함께
johann beda
회원 가입일: 09/13/10
3,428 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 12
전체 시간: 53
