주요 콘텐츠로 건너뛰기
Removing factory feet from a Mac Laptop (Non-Retina)
필요한 것
  1. 이 단계에 사용된 도구:
    Essential Electronics Toolkit
    $23.96
  2. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: 2 단계, 이미지 2개 중 1개 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: 2 단계, 이미지 2개 중 2개
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  3. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: 3 단계, 이미지 3개 중 1개 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: 3 단계, 이미지 3개 중 2개 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: 3 단계, 이미지 3개 중 3개
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  4. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: 4 단계, 이미지 3개 중 1개 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: 4 단계, 이미지 3개 중 2개 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  5. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: 5 단계, 이미지 2개 중 1개 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nick
회원 가입일: 11/10/09
98,168 평판
안내서 61개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,451개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 68
전체 시간: 5,739
