주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Removing fans
필요한 것
  1. Removing fans, Remove screws from bottom of laptop.: 1 단계, 이미지 2개 중 1개 Removing fans, Remove screws from bottom of laptop.: 1 단계, 이미지 2개 중 2개
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
  2. Removing fans, Remove the system board mylar: 3 단계, 이미지 2개 중 1개 Removing fans, Remove the system board mylar: 3 단계, 이미지 2개 중 2개
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
  3. Removing fans, Disconnect tape and cables: 4 단계, 이미지 1개 중 1개
    • (1) Peel off the thermal DIMM plate tape from the system board.
    • (2-3) Lift flap and disconnect the I/O board cable from the system board.
    • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
    • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
    • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
  4. Removing fans, Disconnect the fan cables: 5 단계, 이미지 1개 중 1개
    • Disconnect the three fan cables from the system board by lifting away from board.
  5. Removing fans, Remove screws and fans: 6 단계, 이미지 1개 중 1개
    • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    • Remove tape from fans - possibly using gentle heat
    • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
결론
작성자
1다른 기여자 명과 함께
johann beda
회원 가입일: 09/13/10
3,428 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 68
