주요 콘텐츠로 건너뛰기
Removinging Panasonic DVD-RV31 Player Rear Panel
필요한 것
  1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: 1 단계, 이미지 1/2 Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: 1 단계, 이미지 2/2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Removinging Panasonic DVD-RV31 Player Rear Panel: 2 단계, 이미지 1/1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: 3 단계, 이미지 1/2 Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: 3 단계, 이미지 2/2
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
  4. Removinging Panasonic DVD-RV31 Player Rear Panel: 4 단계, 이미지 1/2 Removinging Panasonic DVD-RV31 Player Rear Panel: 4 단계, 이미지 2/2
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin
회원 가입일: 04/26/11
375 평판
안내서 8개 작성하였습니다
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 회원
CPSU-GARNER-S11S18G20
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 2,285
