주요 콘텐츠로 건너뛰기
Repairing Acer Iconia B1-A71 Touch Screen Digitizer
필요한 것
동영상 개요
  1. Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: 1 단계, 이미지 1/3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: 1 단계, 이미지 2/3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: 1 단계, 이미지 3/3
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • Now, remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Repairing Acer Iconia B1-A71 Touch Screen Digitizer: 2 단계, 이미지 1/3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer: 2 단계, 이미지 2/3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer: 2 단계, 이미지 3/3
결론
다른 15명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 14개
Thanks.. it worked for my tab... Great...
pandawa - 답글
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
omy - 답글
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Andri Sagita - 답글
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
rinayaya - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 15
전체 시간: 39,308
