주요 콘텐츠로 건너뛰기
Repairing LG 17LX1R LCD Television Power board
필요한 것
  1. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 1 단계, 이미지 1/3 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 1 단계, 이미지 2/3 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 1 단계, 이미지 3/3
    • This is the LG 17LX1R that will no longer turn on.
    • Remove the cover from the stand by.
    • Press down on the two tabs. The cover should come off easily.
    • Remove the four screws that hold the stand assembly to the chassis.
  2. Repairing LG 17LX1R LCD Television Power board: 2 단계, 이미지 1/3 Repairing LG 17LX1R LCD Television Power board: 2 단계, 이미지 2/3 Repairing LG 17LX1R LCD Television Power board: 2 단계, 이미지 3/3
    • Remove the four Phillips head screws that attach the stand to the chassis.
    • Remove the eight Phillips screws that hold the back to the chassis. Once the screws are removed, the back will simply snap off.
    • Remove the metal shield. It is fastened with six Phillips screws.
  3. Repairing LG 17LX1R LCD Television Power board: 3 단계, 이미지 1/3 Repairing LG 17LX1R LCD Television Power board: 3 단계, 이미지 2/3 Repairing LG 17LX1R LCD Television Power board: 3 단계, 이미지 3/3
    • After the shield is removed, the power board and the main board are visible.
    • Power Board
    • Main Board
    • Fuse
    • Check all capacitors for blown tops and/or leakage.
    • Thoroughly inspect the boards. Brown discoloration around Diode D102 is evidence of a short circuit, possibly a blown component.
    • Disconnect all connectors from the power board
    • Remove the four screws that mount the power board to the chassis.
  4. Repairing LG 17LX1R LCD Television Power board: 4 단계, 이미지 1/3 Repairing LG 17LX1R LCD Television Power board: 4 단계, 이미지 2/3 Repairing LG 17LX1R LCD Television Power board: 4 단계, 이미지 3/3
    • These are the chassis with the power board removed.
    • Discoloration of the back side of the power board is a sign of a faulty diode.
    • Unsolder the diode from the power board.
    • Replacement diode
  5. Repairing LG 17LX1R LCD Television Power board: 5 단계, 이미지 1/3 Repairing LG 17LX1R LCD Television Power board: 5 단계, 이미지 2/3 Repairing LG 17LX1R LCD Television Power board: 5 단계, 이미지 3/3
    • Here is the removed diode. Description on the diode reads LT526 IN4007.
    • Solder the new diode onto the power board. Use a pair of tweezers or hemostat to hold the diode in place while soldering.
    • Once the diode is replaced, clean the board with isopropyl alcohol to get rid of any debris or old flux.
    Include many telivisions and user manual
    Raz Media - 답글
  6. Repairing LG 17LX1R LCD Television Power board: 6 단계, 이미지 1/1
    • Device powers on and has audio and video after the repair.
결론
다른 37명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,480 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 544개 작성하였습니다
댓글 3개
Very nice good job
Bhullana - 답글
good job my frend
youcef - 답글
great idea thats perfect
Joseph Mwangome - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 34
전체 시간: 10,983
