주요 콘텐츠로 건너뛰기
Repairing Nespresso Aeroccino Plus Motor
  1. Repairing Nespresso Aeroccino Plus Motor, Heat: 1 단계, 이미지 1/1
    • Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
  2. Repairing Nespresso Aeroccino Plus Motor, Open: 2 단계, 이미지 1/2 Repairing Nespresso Aeroccino Plus Motor, Open: 2 단계, 이미지 2/2
    • Open the bottom with a strong screwdriver. Be careful not to break the clips inside
  3. Repairing Nespresso Aeroccino Plus Motor, Prepare: 3 단계, 이미지 1/2 Repairing Nespresso Aeroccino Plus Motor, Prepare: 3 단계, 이미지 2/2
    • Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
  4. Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: 4 단계, 이미지 1/3 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: 4 단계, 이미지 2/3 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: 4 단계, 이미지 3/3
    • Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug.
    • If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable.
    • If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
  5. Repairing Nespresso Aeroccino Plus Motor, Close: 5 단계, 이미지 1/1
    • Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic three times. At last switch must be pressed in.
결론
To proof the function use water.
다른 30명이 해당 안내서를 완성하였습니다.
VauWeh
회원 가입일: 10/19/15
209,996 평판
안내서 255개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
26 회원들
안내서 1,185개 작성하였습니다
댓글 44개
Bravo, vielen Dank. Hat bestens funktioniert, in 5 min war alles erledigt!
jschiedermair - 답글
Many thanks!
I couldn't believe reversing polarity would work, but it did!
J.
jeroenvaneijk - 답글
Yes, it's a miracle. :-)
VauWeh -
If reversing the wires solves your problem then it was just a loose or poor contact at the switch causing the problem.
You are not switching polarity when swapping the wires. Like a light switch, it only serves as a connection/disconnection point for electrical flow.
ekao -
Gibt's da auch eine technische Begründung dazu, warum der bloße Tausch der Motoranschlüsse den Fehler behebt?
Ich würd's nur gerne verstehen.
Georg Sunkler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 194
30일 전: 964
전체 시간: 97,289
