주요 콘텐츠로 건너뛰기
Repairing Nintendo 64 Controller Joystick Replacement
필요한 것
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 1 단계, 이미지 3개 중 1개 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 1 단계, 이미지 3개 중 2개 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 1 단계, 이미지 3개 중 3개
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: 2 단계, 이미지 3개 중 1개 Repairing Nintendo 64 Controller Joystick Replacement: 2 단계, 이미지 3개 중 2개 Repairing Nintendo 64 Controller Joystick Replacement: 2 단계, 이미지 3개 중 3개
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: 3 단계, 이미지 3개 중 1개 Repairing Nintendo 64 Controller Joystick Replacement: 3 단계, 이미지 3개 중 2개 Repairing Nintendo 64 Controller Joystick Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
결론
Test out your controller! It should be feeling like new.
다른 33명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Zillatron
회원 가입일: 08/28/12
1,511 평판
안내서 1개를 작성함
4가이드 댓글
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - 답글
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - 답글
Hi, I've been trying to put a Zedlabz N64 joystick replacement in, and I've managed to install it but having so much trouble trying to get the case back on. I put the original back on and had no issues at all. I've tried everything but can't seem to match it up. Anyone got any ideas?
Gary Ogilvie - 답글
Is the new one too big? Hitting somewhere? You might need to dremel the places where it hits.
Jeff Miller -
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 43
지난 30일: 193
전체 시간: 48,284
