소개
This is a quick guide on replacing a faulty joystick on an N64. If you have a controller with a wobbly joystick, this is the way to resolve your issue.
This can also be considered a mod if you are upgrading the joystick to a redesigned replacement. Upgrading is recommended because the Nintendo 64 has a poorly designed joystick that is prone to breaking and because the redesigned joystick has better control.
필요한 것
Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
Remove the 2 #00 Phillips screws from the expansion slot
Remove the rear housing and set aside.
Test out your controller! It should be feeling like new.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 4개
If you don't line up the z button accurately it can be tricky getting the case back on.
Hi, I've been trying to put a Zedlabz N64 joystick replacement in, and I've managed to install it but having so much trouble trying to get the case back on. I put the original back on and had no issues at all. I've tried everything but can't seem to match it up. Anyone got any ideas?
Is the new one too big? Hitting somewhere? You might need to dremel the places where it hits.
