주요 콘텐츠로 건너뛰기
Repairing Nintendo 64 Controller Joystick Replacement
필요한 것
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 1 단계, 이미지 1/3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 1 단계, 이미지 2/3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 1 단계, 이미지 3/3
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: 2 단계, 이미지 1/3 Repairing Nintendo 64 Controller Joystick Replacement: 2 단계, 이미지 2/3 Repairing Nintendo 64 Controller Joystick Replacement: 2 단계, 이미지 3/3
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: 3 단계, 이미지 1/3 Repairing Nintendo 64 Controller Joystick Replacement: 3 단계, 이미지 2/3 Repairing Nintendo 64 Controller Joystick Replacement: 3 단계, 이미지 3/3
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
결론
Test out your controller! It should be feeling like new.
다른 33명이 해당 안내서를 완성하였습니다.
Zillatron
회원 가입일: 08/28/12
1,511 평판
안내서 1개 작성함
댓글 2개
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - 답글
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 56
30일 전: 216
전체 시간: 44,427
