주요 콘텐츠로 건너뛰기
Repairing TRITTON Kunai Speakers
필요한 것
  1. Repairing TRITTON Kunai Speakers, Repairing TRITTON Kunai Speakers: 1 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers, Repairing TRITTON Kunai Speakers: 1 단계, 이미지 2개 중 2개
    • Firmly hold the black ear cushion with one hand and the white speaker frame with the other hand.
    • Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
  2. Repairing TRITTON Kunai Speakers: 2 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 2 단계, 이미지 2개 중 2개
    • Remove the two 9 mm screws with a PH00 screwdriver.
    • Remove the two 7 mm screws with a PH00 screwdriver.
    • Separate the black horseshoe shaped frame from the right speaker frame.
  3. Repairing TRITTON Kunai Speakers: 3 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 3 단계, 이미지 2개 중 2개
    • Remove the two 7 mm screws using a PH00 screwdriver.
    • Separate the black bracket and then the rail adjustment from the right speaker frame.
  4. Repairing TRITTON Kunai Speakers: 4 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 4 단계, 이미지 2개 중 2개
    • Remove the five 7 mm screws using a PH00 screwdriver.
    • Separate the black speaker console from the right speaker frame.
  5. Repairing TRITTON Kunai Speakers: 5 단계, 이미지 1개 중 1개
    • Place the right speaker console face up with the four speaker terminals situated above the 16 Ohm speaker as pictured.
    • Make sure the red wire is connected to the far right terminal and the green wire is connected to the far left terminal; if this is not the case solder your wires into place. Here is iFixit's soldering guide
    • If you had to solder or reconnect any wires, test your headset before moving on to the next step.
  6. Repairing TRITTON Kunai Speakers: 6 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 6 단계, 이미지 2개 중 2개
    • Repeat steps 1 through 4 of the previous step for the left speaker frame.
    • The photos display the proper placement of the horseshoe shaped hinge within the speaker frame.
  7. Repairing TRITTON Kunai Speakers: 7 단계, 이미지 1개 중 1개
    • Place your left speaker frame on a flat surface with the five metal terminals located on the green chip facing away from you.
    • Make sure the green metal wire is connected to the far left terminal and the red metal wire is connected to the far right terminal. Solder the wires into place if they are not properly connected. Here is iFixit's soldering guide.
    • If you had to solder any wires, test your headset before moving to the next step.
  8. Repairing TRITTON Kunai Speakers: 8 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 8 단계, 이미지 2개 중 2개
    • Forcibly pry the black rubber bracket from the white rail frame. This step causes a small metal bracket inside the rail frame to be dislodged; once this happens the black rubber bracket can be reattached, but the metal bracket cannot be put back into place.
    • Complete this step for the black rubber bracket located on both the right and left sides of the rail adjustment.
  9. Repairing TRITTON Kunai Speakers: 9 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 9 단계, 이미지 2개 중 2개
    • Remove the 7 mm screw with a PH00 screwdriver.
    • Separate the black rubber bracket from the rail adjustment on both sides.
  10. Repairing TRITTON Kunai Speakers: 10 단계, 이미지 2개 중 1개 Repairing TRITTON Kunai Speakers: 10 단계, 이미지 2개 중 2개
    • Firmly hold the black head cushion with one hand and the white rail adjustment with your other hand.
    • Forcibly pull the cushion and rail adjustment in opposite directions until the cushion is completely disconnected.
  11. Repairing TRITTON Kunai Speakers: 11 단계, 이미지 1개 중 1개
    • Reconnect any damaged or disconnected wires and use electrical tape to secure the wires into place.
    • Test your speaker.
    • If your speaker is now working, you can put your headset back together.
    • If your speaker is still not working you need to replace the right speaker. Check out our right speaker repair guide..
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Alexander Glenn
회원 가입일: 03/23/15
171 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G3
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 13
전체 시간: 1,365
