주요 콘텐츠로 건너뛰기
Repairing a Loose Pan Handle
필요한 것
  1. Repairing a Loose Pan Handle, Repairing a Loose Pan Handle: 1 단계, 이미지 3개 중 1개 Repairing a Loose Pan Handle, Repairing a Loose Pan Handle: 1 단계, 이미지 3개 중 2개 Repairing a Loose Pan Handle, Repairing a Loose Pan Handle: 1 단계, 이미지 3개 중 3개
    • Identify the screw keeping the handle in place.
    • Most screws are located on the underside, and a typical pan has only one screw. If there are more, locate them as well.
    • Use a standard Phillips screwdriver to remove the screw(s).
  2. Repairing a Loose Pan Handle: 2 단계, 이미지 3개 중 1개 Repairing a Loose Pan Handle: 2 단계, 이미지 3개 중 2개 Repairing a Loose Pan Handle: 2 단계, 이미지 3개 중 3개
    • Remove the handle and the metal bar to expose the base of the pan handle.
    • The base is where the full handle and the pan meet.
  3. Repairing a Loose Pan Handle: 3 단계, 이미지 3개 중 1개 Repairing a Loose Pan Handle: 3 단계, 이미지 3개 중 2개 Repairing a Loose Pan Handle: 3 단계, 이미지 3개 중 3개
    • Determine what kind of cleaning is required. I used a Lysol solution, which can be substituted with soap and water.
    • If there is rust or burn marks, there are two guides on iFixit by other creators that work well. Their links can be followed by their respective words.
    • Apply your cleaning solution to the base.
    • If necessary, apply cleaning solution to the handle and metal bar, as well.
    • Wipe the area until it is clean, repeat if necessary.
  4. Repairing a Loose Pan Handle: 4 단계, 이미지 2개 중 1개 Repairing a Loose Pan Handle: 4 단계, 이미지 2개 중 2개
    • Identify the warp on the pan, if any.
    • Warps can impact the handle, making it loose or rest incorrectly. This can occur with even small warps, so look closely at your pan.
    • Set the pan on top of a flat cloth.
    • If the warp is going in towards the pan, lay it down with the inside of the pan facing up. If the warp is going out away from the pan, lay it down with the bottom of the pan facing up.
  5. Repairing a Loose Pan Handle: 5 단계, 이미지 1개 중 1개
    • If you do not use cloths, you will scratch the pan when you do Step 6.
    • Cover the warp with a second cloth. We used a different dish towel.
  6. Repairing a Loose Pan Handle: 6 단계, 이미지 1개 중 1개
    • Do not hammer too forcefully otherwise the pan will warp the opposite way.
    • Hammer the warp carefully.
    • It should take 2-3 strikes for smaller warps and more than 3 for bigger warps.
  7. Repairing a Loose Pan Handle: 7 단계, 이미지 2개 중 1개 Repairing a Loose Pan Handle: 7 단계, 이미지 2개 중 2개
    • Take the metal bar and place it back over the base.
  8. Repairing a Loose Pan Handle: 8 단계, 이미지 3개 중 1개 Repairing a Loose Pan Handle: 8 단계, 이미지 3개 중 2개 Repairing a Loose Pan Handle: 8 단계, 이미지 3개 중 3개
    • Align the handle onto the metal bar.
    • Push the handle into the metal bar socket.
    • Put the screw back in the socket.
    • Use the screw driver to tighten the screw.
    • To make sure it's not too loose, pick it up by the handle to test it. If it wobbles it is too loose, and needs to be tightened more.
결론
Repeat this for any number of pans.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Augustus Gunnerson
회원 가입일: 02/18/20
202 평판
안내서 1개를 작성함
UC Davis, Team S1-G2, Andersen Winter 2020 UC Davis, Team S1-G2, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S1G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 107
지난 30일: 434
전체 시간: 24,050
