주요 콘텐츠로 건너뛰기
Repairing an FJ-3LED Globe Electric Push Light
필요한 것
  1. Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 1 단계, 이미지 1/3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 1 단계, 이미지 2/3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 1 단계, 이미지 3/3
    • Lift the black lid off of the battery slot and remove the batteries.
  2. Repairing an FJ-3LED Globe Electric Push Light: 2 단계, 이미지 1/3 Repairing an FJ-3LED Globe Electric Push Light: 2 단계, 이미지 2/3 Repairing an FJ-3LED Globe Electric Push Light: 2 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove four 1.4 mm screws from the back of the light.
    • Take the black part out and separate it from the white case.
  3. Repairing an FJ-3LED Globe Electric Push Light: 3 단계, 이미지 1/1
    • Identify which part of the lamp is broken.
    • in this case, one of the connections in the circuit had been disconnected.
  4. Repairing an FJ-3LED Globe Electric Push Light: 4 단계, 이미지 1/1
    • For tips on Soldering, see How to Solder and Desolder Connections.
    • Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
    • Melt enough solder onto the solder pad.
    • Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
    • Don't forget to use gloves.
  5. Repairing an FJ-3LED Globe Electric Push Light: 5 단계, 이미지 1/2 Repairing an FJ-3LED Globe Electric Push Light: 5 단계, 이미지 2/2
    • Push the circuit into its place.
    • Click the button to see if the wires are connected .
  6. Repairing an FJ-3LED Globe Electric Push Light: 6 단계, 이미지 1/2 Repairing an FJ-3LED Globe Electric Push Light: 6 단계, 이미지 2/2
    • If the lights turn on, the connection is perfect in the circuit and the disconnected joint is now connected.
    • Place the white case on top of the circuit and close it with the Phillips #1 screwdriver.
결론
Rojina Saberi
회원 가입일: 05/11/21
133 평판
안내서 1개 작성함
York University, Team S1-G23, O'Regan Summer 2021 York University, Team S1-G23, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G23
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 348
