주요 콘텐츠로 건너뛰기
Repairing an FJ-3LED Globe Electric Push Light
필요한 것
  1. Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 1 단계, 이미지 3개 중 1개 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 1 단계, 이미지 3개 중 2개 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 1 단계, 이미지 3개 중 3개
    • Lift the black lid off of the battery slot and remove the batteries.
  2. Repairing an FJ-3LED Globe Electric Push Light: 2 단계, 이미지 3개 중 1개 Repairing an FJ-3LED Globe Electric Push Light: 2 단계, 이미지 3개 중 2개 Repairing an FJ-3LED Globe Electric Push Light: 2 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove four 1.4 mm screws from the back of the light.
    • Take the black part out and separate it from the white case.
  3. Repairing an FJ-3LED Globe Electric Push Light: 3 단계, 이미지 1개 중 1개
    • Identify which part of the lamp is broken.
    • in this case, one of the connections in the circuit had been disconnected.
  4. Repairing an FJ-3LED Globe Electric Push Light: 4 단계, 이미지 1개 중 1개
    • For tips on Soldering, see How to Solder and Desolder Connections.
    • Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
    • Melt enough solder onto the solder pad.
    • Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
    • Don't forget to use gloves.
  5. Repairing an FJ-3LED Globe Electric Push Light: 5 단계, 이미지 2개 중 1개 Repairing an FJ-3LED Globe Electric Push Light: 5 단계, 이미지 2개 중 2개
    • Push the circuit into its place.
    • Click the button to see if the wires are connected .
  6. Repairing an FJ-3LED Globe Electric Push Light: 6 단계, 이미지 2개 중 1개 Repairing an FJ-3LED Globe Electric Push Light: 6 단계, 이미지 2개 중 2개
    • If the lights turn on, the connection is perfect in the circuit and the disconnected joint is now connected.
    • Place the white case on top of the circuit and close it with the Phillips #1 screwdriver.
결론
작성자
1다른 기여자 명과 함께
Rojina Saberi
회원 가입일: 05/11/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 577
