소개
If you need to replace the battery from your Dell XPS 13 9380, this guide is for you!
필요한 것
Use a Torx T5 driver to unscrew the eight screws securing the back panel.
Use a spudger to pry up and loosen the back panel.
Lift the back panel up slightly from the non-hinged edge.
Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
When the back panel clips are free, remove the back panel.
Disconnect the cable from the battery by pulling the connector towards the battery.
Remove the four screws (M2 x 2) securing the battery.
Remove the screw (M1.6 x 4) securing the battery.
Remove the battery from its recess.
To reassemble your device, follow the instructions in reverse order.
다른 16명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 3개
The backpanel is a bit tricky to remove, but it can be managed.
The "Essential Electronics Toolkit" is very useful! I recommend to order it with the battery.
I am confused because according to dell.com the battery for the XPS 13 9380 is the G7GV0, not the G8VCF (DXGH8) which you are selling here:
https://www.dell.com/en-uk/shop/dell-4-c...
vs.
The hole for the M1.6x4 screw is too large, allowing the head to go through the hole and not hold the battery. I sawed off the tab from the old battery to use as a washer.
