주요 콘텐츠로 건너뛰기
Replacing an Invisible Zipper
필요한 것
  1. Replacing an Invisible Zipper, Invisible Zipper: 1 단계, 이미지 3개 중 1개 Replacing an Invisible Zipper, Invisible Zipper: 1 단계, 이미지 3개 중 2개 Replacing an Invisible Zipper, Invisible Zipper: 1 단계, 이미지 3개 중 3개
    • Prepare sewing machine with its compatible invisible zipper foot.
    • Thread the needle thread through the invisible zipper foot hole.
    • Pull the needle thread through the zipper foot hole.
  2. Replacing an Invisible Zipper: 2 단계, 이미지 3개 중 1개 Replacing an Invisible Zipper: 2 단계, 이미지 3개 중 2개 Replacing an Invisible Zipper: 2 단계, 이미지 3개 중 3개
    • Locate the stitch lines of where the broken zipper was sewn on both sides of your garment.
    • Use a seam ripper to carefully rip out both of the stitching lines.
    • How to Rip a Seam
    • Make sure to not cut through the fabric.
    • Remove old invisible zipper.
  3. Replacing an Invisible Zipper: 3 단계, 이미지 2개 중 1개 Replacing an Invisible Zipper: 3 단계, 이미지 2개 중 2개
    • Turn the skirt inside out.
    • Place the replacement invisible zipper on the table, with the teeth side pointing up and the zipper pull facing down.
    • Unzip the invisible zipper. Line up the left side of the tape of the invisible zipper with the left side of your fabric.
    • The zipper teeth should 1/8" away from the edge of the fabric.
  4. Replacing an Invisible Zipper: 4 단계, 이미지 2개 중 1개 Replacing an Invisible Zipper: 4 단계, 이미지 2개 중 2개
    • Pin the tape of the zipper to your garment's fabric perpendicular to the invisible zipper.
  5. Replacing an Invisible Zipper: 5 단계, 이미지 2개 중 1개 Replacing an Invisible Zipper: 5 단계, 이미지 2개 중 2개
    • Place the teeth of the left side of the zipper into the right side of the invisible zipper foot.
    • When repeating on the opposite side of the zipper, place the teeth of the right side of the zipper on the left side of the invisible zipper foot.
  6. Replacing an Invisible Zipper: 6 단계, 이미지 3개 중 1개 Replacing an Invisible Zipper: 6 단계, 이미지 3개 중 2개 Replacing an Invisible Zipper: 6 단계, 이미지 3개 중 3개
    • Sew a straight line carefully, removing pins as you go.
    • Repeat Steps 5-8 on the right side of your garment.
  7. Replacing an Invisible Zipper: 7 단계, 이미지 3개 중 1개 Replacing an Invisible Zipper: 7 단계, 이미지 3개 중 2개 Replacing an Invisible Zipper: 7 단계, 이미지 3개 중 3개
    • Turn the skirt right-side out again, so you don't see the zipper teeth.
    • Rotate the fabric so the zipper foot is perpendicular to the zipper tape.
    • Position the zipper foot on top of the fabric 1/8th of an inch from where the zipper tape meets the garment.
    • Sew back and forth at least 6 times to seal the end.
    • This ensures that the zipper tab does not come off when you zip it up.
    • Flip garment over to see the stitch line you just made. Cut off excess zipper tape.
  8. Replacing an Invisible Zipper: 8 단계, 이미지 3개 중 1개 Replacing an Invisible Zipper: 8 단계, 이미지 3개 중 2개 Replacing an Invisible Zipper: 8 단계, 이미지 3개 중 3개
    • Pull up your newly replaced zipper.
    • Be proud of yourself! You've just replaced an invisible zipper!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Katie Woo
회원 가입일: 04/28/17
116 평판
안내서 1개를 작성함
UC Davis, Team S3-G2, Coad Spring 2017 UC Davis, Team S3-G2, Coad Spring 2017 회원
UCD-COAD-S17S3G2
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 26
지난 30일: 92
전체 시간: 13,294
