주요 콘텐츠로 건너뛰기
Retina MacBook 2015 Audio Jack Board Replacement
필요한 것
  1. Retina MacBook 2015 Audio Jack Board Replacement, Unfasten the lower case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If, like me, you didn’t have a P5 Pentalope screwdriver but did have one that fits an iPhone.
    You can sand down the tip until it’s the right size.
    Stuart - 답글
    Thank you Stuart! I would never have thought of this and it worked perfectly.
    R McP -
    Hello,
    where do I plug the USB-C to USB-A cable on MacBook MacBook Pro (Retina, 15-inch, Mid 2015)
    I can’t any port suitable for USB-c !??
    sissi - 답글
    My MacBook had P4 pentalobe screws, notP5
    Greg Lavardera - 답글
    Big thanks to Jeff for such thorough and detailed instructions. This is definitely a more advanced repair so if you're not comfortable with making such repairs, like having experience working on iPhones, computers, etc., you might think twice before attempting. It's very helpful to read all the instructions thoroughly before starting. Plan on 3 to 4 hours—the battery removal along with its adhesive is a real $@$*-show, but totally doable if you followed Jeff's recommendations.
    I'll post a few tips in the comments on each step that I think is worth noting but I will mention here one of the trickier steps. ZIF connectors on the flat cables can be a little tricky, especially if you have never done these. Before attempting to do the first one (step 8) review the others in steps 16, 20, and 25. You'll get a better sense of how these little retaining flaps flip up and what they actually look like when you study each photo in each step—they are very tiny and fragile.
    Steven Gibson - 답글
    Just finished replacing the battery. I followed the directions that came with the battery instead of this guide. In short, Steps 15 to 35 are not necessary. You don't have to completely disassemble the laptop to replace the battery.
    Andrew Mohan - 답글
    Thanks. I skipped it too and it worked.. It was a painstaking to remove the two side batteries as the cables were connected. But a little patience gets the job done. I did however remove the audio jack connector but from the audio board. Removed the display connector and the usb-c bracket to get the bottom case free.
    Paras Tolani -
    READ EVERY STEP, AND EVERY COMMENT FOR THAT STEP BEFORE ATTEMPTING! Go slow. Think first. Be organized. No probs.
    David Nagle - 답글
  2. Retina MacBook 2015 Audio Jack Board Replacement: 2 단계, 이미지 1/3 Retina MacBook 2015 Audio Jack Board Replacement: 2 단계, 이미지 2/3 Retina MacBook 2015 Audio Jack Board Replacement: 2 단계, 이미지 3/3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  3. Retina MacBook 2015 Audio Jack Board Replacement: 3 단계, 이미지 1/1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 Audio Jack Board Replacement: 4 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 4 단계, 이미지 2/2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    This step at the suggested height tears the ribbon cable. do step 7 first. carefully
    Kiernan - 답글
    If you carefully open the display all the way and then lift the upper case, you can let the display rest on your flat working surface. The upper case will be held in place at an appropriate angle by the display hinge.
    Mike C - 답글
    It's a two-spooger-job.
    LMAOOOOOOOO
    Elixir2 - 답글
  5. Retina MacBook 2015 Audio Jack Board Replacement: 5 단계, 이미지 1/3 Retina MacBook 2015 Audio Jack Board Replacement: 5 단계, 이미지 2/3 Retina MacBook 2015 Audio Jack Board Replacement: 5 단계, 이미지 3/3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    Wow okay could someone explain why this is necessary? What happens if you skip this step and simply undo the screw to disconnect the power?
    EB Computers - 답글
    Removing the screw does not disconnect the power—power comes from the battery terminals contacting the underside of the logic board, and they’re tricky to separate reliably at this stage of disassembly. This step is the safest and easiest way to kill power; don’t skip it.
    Jeff Suovanen -
    What if I can’t get my LED to power on when reassembling the machine?
    greg2b - 답글
    Update: Realized my USB-C connector (Step 14) wasn’t properly seated.
    greg2b -
    Hi what will happen if i skip this step, coz i did tried to power down the battery by pressing small gold button, but no avail. the LED light still there even after more than 5 times press (5-10secs or more) each press.
    Dimitri Zaborski - 답글
    Did you learn the answer to your question? I'm having the same issue -- I keep pressing the gold button but the battery light stays on.
    R McP -
    Mi laptop doesn’t turn it on doing that ):
    alexisaguinagam26 - 답글
  6. Retina MacBook 2015 Audio Jack Board Replacement: 6 단계, 이미지 1/1
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 Audio Jack Board Replacement: 7 단계, 이미지 1/1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
    Before the IPD flex cable can be removed the battery disconnect button has be held down for up to 10 seconds. If the LED near the battery connector is switched on it shows that there is power going through the logic board from the battery, once the button is pressed and this light goes off the machine is safe to be worked on.
    Aaron Dalziel - 답글
  8. Retina MacBook 2015 Audio Jack Board Replacement: 8 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 8 단계, 이미지 2/2
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Only peel back the first half of the tape covering the trackpad cable ZIF connector—do not completely remove.
    Steven Gibson - 답글
    Gently - lift tape while wiggling cable side to side. Be sure tape is released, but do not remove completely
    David Nagle - 답글
  9. Retina MacBook 2015 Audio Jack Board Replacement: 9 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 9 단계, 이미지 2/2
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    This is very tricky indeed - at least on my computer. I failed at this point - having skipped to it as sugested above so as not to stress the ribbons on the other side. The ZIF was not as I expected. They had opened when I pulled up the stick cover and I found I was working on the socket itself. The top edge came adrift after almost no pressure being put on it. The ribon did not come free with gentle pulling though. At that point I put the back on again… waited until the battery recharged a bit and found I had not nroken it after all. I doubt I shall try again. It is much harder to replace than the 15 inch - much…
    Simon Anthony - 답글
    I’ve just found that I have broken it after all. No keyboard. Bluetooth still works so I can use the machine.
    All in all, an expensive mistake. BTW - I did NOT get the kit from IFIXIT - not sold here.
    Simon Anthony - 답글
    I found “Recognizing & Disconnecting Cable Connectors”
    케이블 커넥터 인식 및 분리
    useful, esp. for someone who has not used ZIF connectors and retaining flaps before. There are several retaining flaps that need to be opened. The first time is tricky as you need a sense of how much force to apply. I used the flat end of the provided spudger. Apply progressively firmer upward pressure until the retaining flap pops open. The first time is tricky, but straightforward thereafter.
    Ki Park - 답글
    Mouse back and forth between the two right-side thumbnail photos and you will get a little animation feel showing how these ZIF connectors operate—it's very helpful. Apply light but consistent pressure to pop them up. Helps to go side to side if they're a little stubborn.
    Steven Gibson - 답글
    this is a great tip Steve!
    Eric - 답글
  10. Retina MacBook 2015 Audio Jack Board Replacement: 10 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 10 단계, 이미지 2/2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    it would be nice to have a specific picture of the cable and contacts and how it is oriented in the ZIF connector. This isn't clear in any of these photos or text.
    My trackpad cable snapped so had to replace it and none of the replacement cables have the tape which is on the smaller end to the trackpad. The other end is fairly easy to figure out but the trackpad end isn't as the cable makes a 180 degree turn inside the case (poor design).
    Marc - 답글
  11. Retina MacBook 2015 Audio Jack Board Replacement: 11 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 11 단계, 이미지 2/2
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
    You can open the laptop screen all the way open with it flat in the table (screen facing up) and the keyboard should stay up.
    xavierviveros - 답글
  12. Retina MacBook 2015 Audio Jack Board Replacement: 12 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 12 단계, 이미지 2/2
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    the moment you opening macbook case and before any tinkering with connections, you MUST press little yellow button on logicboard, located on the right from battery connector - this will disable all power to the board. You can check by looking at the small led on left side of the battery connector - if there is very faint light, it means that power is still there. After pressing button light should go off. Removing screw is not necessary at all, and like I said - you MUST disable power before any touching to connections etc.
    DigiHead - 답글
    Where it says
    “2015 models have a silver grounding clip with two foam pads directly under this screw“
    I have a 2015 MacBook & the grounding clip is not there!
    I’m using this guide to investigate why there are lines on screen or darker screen at certain angles of opening it. Also a background ghosting effect on screen too.
    No obvious damage or loose connectors so wondered if the lack of grounding clip can cause these symptoms?
    Anybody out there know?
    nijafe - 답글
    Either buy the clip and check, or replace the screen (or LB), but the macbook would more likely not start if there is a missing grounded connection, depending on what is being grounded.
    Sean -
  13. Retina MacBook 2015 Audio Jack Board Replacement: 13 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 13 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Battery Blocker
    $3.99
    구매
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    I HAD TO DO THIS TWICE. After replacing the battery while following this guide to a 'T', the battery was not being recognized by the logic board. Strangely, with the power unplugged it would still light up the screen and tell me the battery was at a critical level, but it would not boot. Resetting the SMC had no effect. I thought I killed my computer or got a bad battery, so as a last ditch effort I re-opened the case, pressed the battery disconnect button, removed the screw and inserted the battery separation tool again to Physically Disconnect the battery from the mainboard. After about 5 minutes I then removed the tool and reassembled everything, plugged in via 5v iphone charger and USBA-C cable again and LO, the battery is now reporting correctly, charging correctly and allowing me to boot on its power .
    Neil Schultz - 답글
  14. Retina MacBook 2015 Audio Jack Board Replacement: 14 단계, 이미지 1/1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
    This was oddly the hardest part. That Tri-Point screw just wouldn’t budge! I had to sand the end of the only Tri-point screwdriver I had in the end to get it to fit.
    Stuart - 답글
    Be sure to get the metal plate under the chip near where the PT5 screw is before tightening
    abscate - 답글
    I should have read the comments before using the provided 1.1 mm Tri-point Y00 bit. I almost stripped the screw but was able to use a small flat head bit to open the screw.
    Ifixit: you may want to update this part in the instructions. Not everyone reads the comment section, esp. when it comes to specification of bits which is basic and must be accurate. This is one of the more critical ones in the procedure that can easily go south. The rest of the instructions are excellent.
    Ki Park - 답글
    early 2015 model here. I’ve used a Y1.5 with cautiously applied down force.
    beaudry.ian - 답글
    My 2015 had a 2.5mm Y screw not a Y000.
    Michael Bonney - 답글
    Adding to the helpful comments above, on replacing the 1.1mm tripoint screw, I found the the magnetism of the nearby speaker coil overcame that of the driver and would draw the screw away or the combo of forces would fling it out of the work area! After fiddling with it for too long, I used some of the battery adhesive removed earlier to attached the screw to the driver. Wax would probably work better if I’d had some.
    jefflyons - 답글
    I used the PH00 head to unscrew what they call the “1.1 mm Tri-point Y00 screw”, NOT the Y00 head, and it unscrewed perfectly fine.
    Grace Escamilla - 답글
    Agreed, my screw was a PH00.
    stephen delaney - 답글
    I have an early 2015 MacBook and it was a PH00 head I needed to use.
    Sean Stein - 답글
  15. Retina MacBook 2015 Audio Jack Board Replacement: 15 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 15 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    Emphasis on aligning the bracket correctly. What the pictures do not show is that underneath the flat part of the metal bracket (the area between the two screw holes) is a connector that needs to be accurately aligned. Aligning the two screw holes does not imply that the connector is seated correctly.
    After I re-assembled my 2015 MacBook power would not come on. I thought I had damaged the logic board despite being careful and following instructions. Diagnosing the problem took a while. Retracing the steps and focusing on power supply I was able to determine that the metal flap which hides the connector underneath had not made proper contact.
    What I did was to use a finger to get a tactile feel for the connector underneath the metal bracket aligning properly and then press down vertically when it seemed to be aligned. It’s a subtle tactile feel. After re-doing this step, I got power back. Be careful not to damage the connector as noted in the instructions.
    Ki Park - 답글
    Good tip. It’s so easy to damage these fragile connectors by forcing the plug in and reattaching the mounting plate screws
    Peter Newman -
  16. Retina MacBook 2015 Audio Jack Board Replacement: 16 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 16 단계, 이미지 2/2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 Audio Jack Board Replacement: 17 단계, 이미지 1/1
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
    hey my macbook do not have sound after replacing the topcase, i did connect everything like here you did, also I did the reset of PR and NVRAM. What Can I check more? simply when I open the OS, there is no audio device at all
    dkflu - 답글
    The audio jack cable is a bit of a pain to reinsert. I found if I turned the screen and the bottom on its side, like an open book, I had much better orientation and it was much easier to insert.
    Steven Gibson - 답글
    Excellent guide and all works like a sharm, but was one issue. After full assemble there wasn't sound. Then I open Macbook again and disconnect and connect audio cable. You must insert cable so, that white stripe will not visible. And sound reveal!
    Pzs Serv - 답글
    This helped me, thanks!
    Egbert Kappert -
  18. Retina MacBook 2015 Audio Jack Board Replacement, Audio Jack Board: 18 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement, Audio Jack Board: 18 단계, 이미지 2/2
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
  19. Retina MacBook 2015 Audio Jack Board Replacement: 19 단계, 이미지 1/2 Retina MacBook 2015 Audio Jack Board Replacement: 19 단계, 이미지 2/2
    • Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
    Does anyone know were I can buy the “microphone assembly ribbon cable“? It is the most delicate cable and cant seem to find spare part.
    Vernon Roth - 답글
  20. Retina MacBook 2015 Audio Jack Board Replacement: 20 단계, 이미지 1/1
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
  21. Retina MacBook 2015 Audio Jack Board Replacement: 21 단계, 이미지 1/1
    • Remove the audio jack board.
    After jack replacement my internal speakers stop working. Any solution?
    piotr2503 - 답글
    There must be a bad contact in the jack socket or the card has been damaged, the sound therefore remains blocked on it
    Ludovic - 답글
결론
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
다른 3명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
428,128 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
https://d3nevzfk7ii3be.cloudfront.net/ig...
Please Can Someone Tell me Where i Can Buy a Replacement Ribbon Like the One Shown in this Picture? i Damaged Mine And Now The Macbook is Dead.
Hass Houss - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 21
30일 전: 64
전체 시간: 13,202
