주요 콘텐츠로 건너뛰기
Retina MacBook 2015 Dual Microphone Assembly Replacement
필요한 것
  1. Retina MacBook 2015 Dual Microphone Assembly Replacement, Unfasten the lower case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Retina MacBook 2015 Dual Microphone Assembly Replacement: 2 단계, 이미지 3개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 2 단계, 이미지 3개 중 2개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  3. Retina MacBook 2015 Dual Microphone Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 Dual Microphone Assembly Replacement: 4 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  5. Retina MacBook 2015 Dual Microphone Assembly Replacement: 5 단계, 이미지 3개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 5 단계, 이미지 3개 중 2개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  6. Retina MacBook 2015 Dual Microphone Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 Dual Microphone Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  8. Retina MacBook 2015 Dual Microphone Assembly Replacement: 8 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  9. Retina MacBook 2015 Dual Microphone Assembly Replacement: 9 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  10. Retina MacBook 2015 Dual Microphone Assembly Replacement: 10 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  11. Retina MacBook 2015 Dual Microphone Assembly Replacement: 11 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  12. Retina MacBook 2015 Dual Microphone Assembly Replacement: 12 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
  13. Retina MacBook 2015 Dual Microphone Assembly Replacement: 13 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Battery Blocker
    $3.99
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  14. Retina MacBook 2015 Dual Microphone Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
  15. Retina MacBook 2015 Dual Microphone Assembly Replacement: 15 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 15 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  16. Retina MacBook 2015 Dual Microphone Assembly Replacement: 16 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 16 단계, 이미지 2개 중 2개
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 Dual Microphone Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
  18. Retina MacBook 2015 Dual Microphone Assembly Replacement, Audio Jack Board: 18 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement, Audio Jack Board: 18 단계, 이미지 2개 중 2개
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
  19. Retina MacBook 2015 Dual Microphone Assembly Replacement: 19 단계, 이미지 2개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 19 단계, 이미지 2개 중 2개
    • Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
  20. Retina MacBook 2015 Dual Microphone Assembly Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
  21. Retina MacBook 2015 Dual Microphone Assembly Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the audio jack board.
  22. Retina MacBook 2015 Dual Microphone Assembly Replacement, Dual Microphone Assembly: 22 단계, 이미지 1개 중 1개
    • Prepare an iOpener and apply heat to the upper case directly behind the microphone assembly.
  23. Retina MacBook 2015 Dual Microphone Assembly Replacement: 23 단계, 이미지 3개 중 1개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 23 단계, 이미지 3개 중 2개 Retina MacBook 2015 Dual Microphone Assembly Replacement: 23 단계, 이미지 3개 중 3개
    • Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case.
  24. Retina MacBook 2015 Dual Microphone Assembly Replacement: 24 단계, 이미지 1개 중 1개
    • Remove the dual microphone assembly.
결론
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
92,026 평판
안내서 89개를 작성함
3가이드 댓글
Hi! Anyone would know where to find the MacBook 2015 Dual Microphone only? iFixIt seems to have it listed already assembled with the MacBook Upper Part with Keyboard. It does not seem to list this part separately. Thanks!
Neo_Hunt - 답글
Found the new mic assembly on ebay and amazon. Part 2243-A
Erick Luna - 답글
댓글 쓰기
조회 통계:
지난 24시간: 50
지난 7일: 387
지난 30일: 895
전체 시간: 7,312
