주요 콘텐츠로 건너뛰기
Retina MacBook 2015 Logic Board Replacement
필요한 것
  1. Retina MacBook 2015 Logic Board Replacement, Unfasten the lower case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Retina MacBook 2015 Logic Board Replacement: 2 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 2 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 2 단계, 이미지 3개 중 3개
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  3. Retina MacBook 2015 Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 Logic Board Replacement: 4 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  5. Retina MacBook 2015 Logic Board Replacement: 5 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 5 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 5 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  6. Retina MacBook 2015 Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  8. Retina MacBook 2015 Logic Board Replacement: 8 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  9. Retina MacBook 2015 Logic Board Replacement: 9 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  10. Retina MacBook 2015 Logic Board Replacement: 10 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  11. Retina MacBook 2015 Logic Board Replacement: 11 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 11 단계, 이미지 2개 중 2개
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  12. Retina MacBook 2015 Logic Board Replacement: 12 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
  13. Retina MacBook 2015 Logic Board Replacement: 13 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Battery Blocker
    $3.99
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  14. Retina MacBook 2015 Logic Board Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
  15. Retina MacBook 2015 Logic Board Replacement: 15 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 15 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  16. Retina MacBook 2015 Logic Board Replacement: 16 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 16 단계, 이미지 2개 중 2개
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 Logic Board Replacement: 17 단계, 이미지 1개 중 1개
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
  18. Retina MacBook 2015 Logic Board Replacement, Retina MacBook 2015 Lower Case Assembly Removal: 18 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement, Retina MacBook 2015 Lower Case Assembly Removal: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to peel back the tape covering the display cable connector.
  19. Retina MacBook 2015 Logic Board Replacement: 19 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 19 단계, 이미지 2개 중 2개
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  20. Retina MacBook 2015 Logic Board Replacement: 20 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
  21. Retina MacBook 2015 Logic Board Replacement: 21 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 21 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 21 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iOpener
    $14.99
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
  22. Retina MacBook 2015 Logic Board Replacement: 22 단계, 이미지 1개 중 1개
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
  23. Retina MacBook 2015 Logic Board Replacement: 23 단계, 이미지 1개 중 1개
    • Separate the upper case assembly from the lower case assembly.
  24. Retina MacBook 2015 Logic Board Replacement, Logic Board: 24 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement, Logic Board: 24 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement, Logic Board: 24 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
  25. Retina MacBook 2015 Logic Board Replacement: 25 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 25 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 25 단계, 이미지 3개 중 3개
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  26. Retina MacBook 2015 Logic Board Replacement: 26 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 26 단계, 이미지 2개 중 2개
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  27. Retina MacBook 2015 Logic Board Replacement: 27 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 27 단계, 이미지 2개 중 2개
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  28. Retina MacBook 2015 Logic Board Replacement: 28 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 28 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 28 단계, 이미지 3개 중 3개
    • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
  29. Retina MacBook 2015 Logic Board Replacement: 29 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 29 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 29 단계, 이미지 3개 중 3개
    • Pry up the second antenna connector to disconnect it.
  30. Retina MacBook 2015 Logic Board Replacement: 30 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 30 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
  31. Retina MacBook 2015 Logic Board Replacement: 31 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 31 단계, 이미지 2개 중 2개
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  32. Retina MacBook 2015 Logic Board Replacement: 32 단계, 이미지 2개 중 1개 Retina MacBook 2015 Logic Board Replacement: 32 단계, 이미지 2개 중 2개
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
    • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
  33. Retina MacBook 2015 Logic Board Replacement: 33 단계, 이미지 1개 중 1개
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  34. Retina MacBook 2015 Logic Board Replacement: 34 단계, 이미지 3개 중 1개 Retina MacBook 2015 Logic Board Replacement: 34 단계, 이미지 3개 중 2개 Retina MacBook 2015 Logic Board Replacement: 34 단계, 이미지 3개 중 3개
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
    • Reattach the tape securely during reassembly.
  35. Retina MacBook 2015 Logic Board Replacement: 35 단계, 이미지 1개 중 1개
    • Remove the logic board.
결론
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
다른 46명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jeff Suovanen
회원 가입일: 08/06/13
447,203 평판
안내서 259개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,640개를 작성함
7가이드 댓글
While this may be difficult for some, a little patience and a light touch make this easier than it first appears.
Steve - 답글
successfully change my motherboard..Thanks for the guide
hanifah jusoh - 답글
Good Guide, easy to follow. Well Done!
Marco Mancin - 답글
if my 2015 12" macbook 1.3 ghz with 512 gb is slow will swapping out the board make it quick again?
daniel s - 답글
Hi Daniel. Swapping the board is more of a last-resort if something is broken. There are many possible reasons your MacBook is running slow. Running much newer software, having bloatware installed, and a variety of smaller factors all play into the speed of your laptop. Look around online for ways to clean up your drive!
Clay Eickemeyer -
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 432
지난 30일: 1,555
전체 시간: 67,376
