소개
The USB-C port on your Retina MacBook 2017 is the only port besides the headphone jack, and may suffer wear or damage over time. Use this guide to replace it.
필요한 것
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Remove the following eight screws securing the lower case:
Two 1.8 mm P5 Pentalobe screws
Four 2.9 mm P5 Pentalobe screws
Two 6.1 mm P5 Pentalobe screws
Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
Remove the two screws securing the USB-C port cable bracket:
1.1 mm Phillips #00 screw
3.5 mm T5 Torx screw
Use tweezers to peel back the tape covering the display cable connector.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 12개
My first time using ifixit website and repair was a success . Mac store quoted over $700 for this repair. I was able to buy new usb-c part and tools for $87 and perform the repair myself. Thanks for your help, could have done it without excellent repair guide which had many useful pictures.
Thanks again, Marcus
Congrats on the repair Marcus. Glad to hear the guide helped.
Same exact situation as Marcus - first time using a guide here (and first time opening a macbook) and the repair was a success! Fried my USB-C and Apple quoted me $600 for repairs. Got the part and tools from ifixit, and along with this incredibly helpful guide, I was able to get it repaired in a couple hours. Thank you so much for putting together such a helpful and informative guide!
Hello. Can i replace usb-c port for 2017 macbook 12 with usp-c port of 2015 model? And if I can’t why?
