주요 콘텐츠로 건너뛰기
Revlon RVDR5061 Fan/Motor Assembly Replacement
필요한 것
  1. Revlon RVDR5061 Fan/Motor Assembly Replacement, Fan/Motor Assembly: 1 단계, 이미지 1/1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Fan/Motor Assembly Replacement: 2 단계, 이미지 1/1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Fan/Motor Assembly Replacement: 3 단계, 이미지 1/1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Fan/Motor Assembly Replacement: 4 단계, 이미지 1/3 Revlon RVDR5061 Fan/Motor Assembly Replacement: 4 단계, 이미지 2/3 Revlon RVDR5061 Fan/Motor Assembly Replacement: 4 단계, 이미지 3/3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
결론
Curtis
회원 가입일: 07/11/18
159 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Wilson Summer 2018 IUPUI, Team S2-G2, Wilson Summer 2018 회원
IUPUI-WILSON-SU18S2G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 1,077
